Data Link Layer Protocol Simulator User Guide - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2008
Emmanuel Nataf
The data link layer protocol simulator allows to write protocol and to see them in execution. This guide describes a step by step approach from simple information communication without any control to windows protocols. A protocol oriented java API is defined to write protocol algorithms.
RR-6417.pdf (230.42 Ko) Télécharger le fichier
inria-00205027 , version 1 (16-01-2008)
inria-00205027 , version 2 (17-01-2008)
  • HAL Id : inria-00205027 , version 2
Emmanuel Nataf. Data Link Layer Protocol Simulator User Guide. [Technical Report] RR-6417, INRIA. 2008, pp.15. ⟨inria-00205027v2⟩
331 Consultations
1412 Téléchargements
