s'authentifier
version française rss feed
inria-00211875, version 2
Worst-Case Hermite-Korkine-Zolotarev Reduced Lattice Bases
Guillaume Hanrot () a1, Damien Stehlé () b2
N° RR-6422 (2008)
Résumé : The Hermite-Korkine-Zolotarev reduction plays a central role in strong lattice reduction algorithms. By building upon a technique introduced by Ajtai, we show the existence of Hermite-Korkine-Zolotarev reduced bases that are arguably least reduced. We prove that for such bases, Kannan's algorithm solving the shortest lattice vector problem requires~$d^{\frac{d}{2\e}(1+o(1))}$ bit operations in dimension~$d$. This matches the best complexity upper bound known for this algorithm. These bases also provide lower bounds on Schnorr's constants~$\alpha_d$ and~$\beta_d$ that are essentially equal to the best upper bounds. Finally, we also show the existence of particularly bad bases for Schnorr's hierarchy of reductions.
  • Domaine : Informatique/Complexité
    Informatique/Cryptographie et sécurité
    Mathématiques/Théorie des nombres
  • Mots-clés : Lattice basis reduction – shortest vector problem – HKZ-reduction – BKZ-reduction
  • Référence interne : RR-6422
  • Versions disponibles :  v1 (22-01-2008) v2 (24-01-2008)
  • inria-00211875, version 2
  • oai:hal.inria.fr:inria-00211875
  • Contributeur :
  • Soumis le : Jeudi 24 Janvier 2008, 16:12:59
  • Dernière modification le : Mercredi 5 Mars 2008, 09:49:36
tous les articles de la base du CCSd...
