A semantic normalization proof for a system with recursors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
Semantics methods have been used to prove cut elimination theorems for a long time. It is only recently that they have been extend to prove strong normalization results, in particular for theories in deduction modulo. However such semantic methods did not apply for systems with recursors like Godel system T. We show in this paper how super natural deduction provides a bridge between superconsistency of arithmetic and strong normalization of system T. We then generalize this result to a family of inductive types before discussing the dependant case.
paper.pdf (174.34 Ko) Télécharger le fichier
inria-00211877 , version 1 (22-01-2008)
  • HAL Id : inria-00211877 , version 1
Lisa Allali, Paul Brauner. A semantic normalization proof for a system with recursors. 2008. ⟨inria-00211877⟩
165 Consultations
111 Téléchargements
