inria-00226418, version 1
Variational Tetrahedral Meshing
Pierre Alliez
a, 1David Cohen-Steiner
a, 1Mariette Yvinec
a, 1Mathieu Desbrun
b, 2
ACM Transactions on Graphics (2005)
Résumé : In this paper, a novel Delaunay-based variational approach to isotropic tetrahedral meshing is presented. To achieve both robustness and efficiency, we minimize a simple mesh-dependent energy through global updates of both vertex positions \italic{and} connectivity. As this energy is known to be the ${\cal L}^1$ distance between an isotropic quadratic function and its linear interpolation on the mesh, our minimization procedure generates well-shaped tetrahedra. Mesh design is controlled through a gradation smoothness parameter and selection of the desired number of vertices. We provide the foundations of our approach by explaining both the underlying variational principle and its geometric interpretation. We demonstrate the quality of the resulting meshes through a series of examples.
- a – INRIA
- b – California Institute of Technology
- 1 : GEOMETRICA (INRIA Sophia Antipolis)
- INRIA
- 2 : Computer Science Department (CS CALTECH)
- California Institute of Technology
- Domaine : Informatique/Géométrie algorithmique
- Mots-clés : Isotropic meshing – Delaunay mesh – sizing field – slivers
- inria-00226418, version 1
- http://hal.inria.fr/inria-00226418
- oai:hal.inria.fr:inria-00226418
- Contributeur : Mariette Yvinec
- Soumis le : Mercredi 30 Janvier 2008, 16:19:29
- Dernière modification le : Mardi 28 Avril 2009, 16:29:10
Documents associés
Exporter
