On the relation between Multicomponent Tree Adjoining Grammars with Tree Tuples (TT-MCTAG) and Range Concatenation Grammars (RCG)
This paper investigates the relation between TT-MCTAG, a formalism used in computational linguistics, and RCG. RCGs are known to describe exactly the class PTIME; simple RCG even have been shown to be equivalent to linear context-free rewriting systems, i.e., to be mildly context-sensitive. TT-MCTAG has been proposed to model free word order languages. In general, it is NP-complete. In this paper, we will put an additional limitation on the derivations licensed in TT-MCTAG. We show that TT-MCTAG with this additional limitation can be transformed into equivalent simple RCGs. This result is interesting for theoretical reasons (since it shows that TT-MCTAG in this limited form is mildly context-sensitive) and, furthermore, even for practical reasons: We use the proposed transformation from TT-MCTAG to RCG in an actual parser that we have implemented.
