A Local Surface Model applied to Contact Line Dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Theory, Methods and Applications Année : 2005
We consider a set of equations modelling contact line dynamics. The model consists of the Navier-Stokes free surface flow with local slip type boundary conditions and gradient surface tension coupled with a mesoscopic local surface model (nonlinear degenerated equations) describes the surface tension variations. The dynamical contact angle and the local surface tension variations are unknowns of the model. We present some mathematical and numerical results.
NA_4440_main_1_.pdf (256.69 Ko) Télécharger le fichier
inria-00256607 , version 1 (15-02-2008)
Jerome Monnier, Patrick Witomski. A Local Surface Model applied to Contact Line Dynamics. Nonlinear Analysis: Theory, Methods and Applications, 2005, 63 (5-7), pp.1551-1559. ⟨10.1016/j.na.2005.01.049⟩. ⟨inria-00256607⟩
116 Consultations
124 Téléchargements
