Monitoring Peer to Peer Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper, we are concerned with the distributed monitoring of P2P systems. We introduce the P2P Monitor system and a new declarative language, namely P2PML, for specifying monitoring tasks. A subscription is compiled into a distributed algebraic plan which is described using an algebra over XML streams. We introduce a filter for streams of XML documents that scales by processing first simple conditions and then, if still needed, evaluating complex queries. We also show how particular tasks can be supported by identifying subtasks already provided by existing streams.
bda-p2pmonitor.pdf (645.52 Ko) Télécharger le fichier
inria-00259064 , version 1 (26-02-2008)
  • HAL Id : inria-00259064 , version 1
Serge Abiteboul, Bogdan Marinoiu. Monitoring Peer to Peer Systems. Bases de données avancées, Oct 2007, Marseille, France. ⟨inria-00259064⟩
98 Consultations
86 Téléchargements
