Generic Mesh Refinement On GPU - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Many recent publications have shown that a large variety of computation involved in computer graphics can be moved from the CPU to the GPU, by a clever use of vertex or fragment shaders. Nonetheless there is still one kind of algorithms that is hard to translate from CPU to GPU: mesh refinement techniques. The main reason for this, is that vertex shaders available on current graphics hardware do not allow the generation of additional vertices on a mesh stored in graphics hardware. In this paper, we propose a general solution to generate mesh refinement on GPU. The main idea is to define a generic refinement pattern that will be used to virtually create additional inner vertices for a given polygon. These vertices are then translated according to some procedural displacement map defining the underlying geometry (similarly, the normal vectors may be transformed according to some procedural normal map). For illustration purpose, we use a tesselated triangular pattern, but many other refinement patterns may be employed. To show its flexibility, the technique has been applied on a large variety of refinement techniques: procedural displacement mapping, as well as more complex techniques such as curved PN-triangles or ST-meshes.
GenericMeshRefinementOnGPU.pdf (1.97 Mo) Télécharger le fichier
inria-00260838 , version 1 (05-03-2008)
  • HAL Id : inria-00260838 , version 1
Tamy Boubekeur, Christophe Schlick. Generic Mesh Refinement On GPU. ACM SIGGRAPH/Eurographics Symposium on Graphics Hardware, Jul 2005, Los Angeles, United States. ⟨inria-00260838⟩
229 Consultations
956 Téléchargements
