Surface Reconstruction with Enriched Reproducing Kernel Particle Approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
There are many techniques that reconstruct continuous 3D surfaces from scattered point data coming from laser range scanners. One of the most commonly used representations are Point Set Surfaces (PSS) defined as the set of stationary points of a Moving Least Squares (MLS) projection operator. One interesting property of the MLS projection is to automatically filter out high frequency noise, that is usually present in raw data due to scanning errors. Unfortunately, the MLS projection also smoothes out any high frequency feature, such as creases or corners, that may be present in the scanned geometry, and does not offer any possibility to distinguish between such feature and noise. The main contribution of this paper, is to present an alternative projection operator for surface reconstruction, based on the Enriched Reproducing Kernel Particle Approximation (ERKPA), which allows the reconstruction process to account for high frequency features, by letting the user explicitly tag the corresponding areas of the scanned geometry.
erkpa.pdf (223.46 Ko) Télécharger le fichier
inria-00260890 , version 1 (05-03-2008)
  • HAL Id : inria-00260890 , version 1
Patrick Reuter, Pierre Joyot, Jean Trunzler, Tamy Boubekeur, Christophe Schlick. Surface Reconstruction with Enriched Reproducing Kernel Particle Approximation. EUROGRAPHICS Symposium on Point-Based Graphics, Jul 2005, New York, United States. ⟨inria-00260890⟩
242 Consultations
311 Téléchargements
