Scalable Freeform Deformation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this sketch, we propose a system for applying interactive deformation on large models. This system is based on two new algorithms performing (pre-)adaptive sampling and (post-)deformation on a geomtric stream, and allows to perform interactive deformation on arbitrary large models. The complete idea is discussed in the full paper "SIMOD: Making Freeform Deformation Size-Insensitive", published in the proceedings of the Eurographics Symposium on Point-Based Graphics 2007 and available online (http://iparla.labri.fr/publications/2007/BSS07a/).
ScalableFFD.pdf (594.51 Ko) Télécharger le fichier
inria-00260941 , version 1 (05-03-2008)
  • HAL Id : inria-00260941 , version 1
Tamy Boubekeur, Olga Sorkine, Christophe Schlick. Scalable Freeform Deformation. ACM SIGGRAPH Sketch Program, Aug 2007, San Diego, United States. ⟨inria-00260941⟩
222 Consultations
162 Téléchargements
