Collaborative Multidisciplinary Design in Virtual Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
The application designers can usually define their own “virtual environments” by selecting the appropriate computing resources required, or reuse and compose existing environments. The approach is generic by allowing various application domains to benefit from potential hardware and software resources located on remote computing facilities in a simple and intuitive way. The computing resources are defined by services made available as sets of standardized interfaces performing specific tasks: application workflow, input data streams, output visualization tools, monitoring facilities, etc. Services can be composed and hierarchically defined. Transparent access to heterogeneous hardware and software operating systems is guaranteed. An aeroelasticity example in airliner design is given.
cscwd2006.pdf (466.76 Ko) Télécharger le fichier
inria-00260996 , version 1 (06-03-2008)
  • HAL Id : inria-00260996 , version 1
Toan Nguyen, Vittorio Selmin. Collaborative Multidisciplinary Design in Virtual Environments. Computer Supported Collaborative Work in Design, Nanjing University, May 2006, Nanjing, China. ⟨inria-00260996⟩
175 Consultations
207 Téléchargements
