Recovering a Code's Length and Synchronisation from a Noisy Intercepted Bitstream - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
Mathieu Cluzeau
  • Fonction : Auteur
  • PersonId : 847426
We focus on the problem of recovering the length and synchronization of a linear block code from an intercepted bitstream. We place ourselves in an operational context where the intercepted bitstream contains a realistic noise level. We present two algorithms, both useful in different contexts, able to verify if a given length/synchronization is correct. Using them, we were able to practically recover the synchronization of several codes.
CluzeauFiniasz.pdf (99.48 Ko) Télécharger le fichier
inria-00261473 , version 1 (07-03-2008)
  • HAL Id : inria-00261473 , version 1
Mathieu Cluzeau, Matthieu Finiasz. Recovering a Code's Length and Synchronisation from a Noisy Intercepted Bitstream. 2008. ⟨inria-00261473⟩
Collections
INRIA INRIA2
113 Consultations
283 Téléchargements
