Spectral Probing : Multi-Spectral Imaging by OptimizedWide Band Illumination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Cui Chi
  • Fonction : Auteur
  • PersonId : 847650
Moshe Ben-Ezra
  • Fonction : Auteur
  • PersonId : 847651
We present a novel active imaging approach that uses optimized wide band filtered illumination to obtain multispectral reflectance information. Our optimization algorithm utilizes light source and camera spectral information in order to maximize the signal strength and the robustness to noise. Through the use of active wide band illumination, our system can obtain material reflectance information in the presence of moderate (indoor) unknown ambient illumination. Our method is very simple and does not require special equipment. It can be used by professional and amateur photographers alike to obtain material properties and to synthesize captured scenes under arbitrary illumination.
p20.pdf (5.5 Mo) Télécharger le fichier
inria-00264804 , version 1 (18-03-2008)
  • HAL Id : inria-00264804 , version 1
Cui Chi, Moshe Ben-Ezra. Spectral Probing : Multi-Spectral Imaging by OptimizedWide Band Illumination. Proceedings of the First International Workshop on Photometric Analysis For Computer Vision - PACV 2007, Oct 2007, Rio de Janeiro, Brazil. 8 p. ⟨inria-00264804⟩
Collections
PACV2007
80 Consultations
151 Téléchargements
