Propagated Photoconsistency and Convexity in Variational Multiview 3D Reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Kalin Kolev
  • Fonction : Auteur
  • PersonId : 847733
Maria Klodt
  • Fonction : Auteur
  • PersonId : 847734
Thomas Brox
  • Fonction : Auteur
  • PersonId : 847735
Daniel Cremers
  • Fonction : Auteur
  • PersonId : 847736
In this paper, we make two contributions. Firstly, we replace the generic balloon constraints widely used in 3D reconstruction by a more sophisticated data-dependent regional term. The key idea is to propagate classical photoconsistency along visual rays into regional values describing voxel probabilities for being inside or outside the observed object. Secondly, we cast the optimization as one of minimizing a convex functional. Therefore (up to visibility) the reconstruction problem can be solved in a globally optimal manner in a spatially continuous setting. Compared to graph cut methods, this approach does not suffer from discretization artifacts and exhibits considerable reduction in memory requirements. Experimental comparisons clearly show the advantages of the proposed technique.
p24.pdf (708.82 Ko) Télécharger le fichier
inria-00265725 , version 1 (20-03-2008)
  • HAL Id : inria-00265725 , version 1
Kalin Kolev, Maria Klodt, Thomas Brox, Daniel Cremers. Propagated Photoconsistency and Convexity in Variational Multiview 3D Reconstruction. Proceedings of the First International Workshop on Photometric Analysis For Computer Vision - PACV 2007, Oct 2007, Rio de Janeiro, Brazil. 8 p. ⟨inria-00265725⟩
Collections
PACV2007
215 Consultations
214 Téléchargements
