Minimizing the Reprojection Error in Surface Reconstruction from Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper addresses the problem of image-based surface reconstruction. The main contribution is the computation of the exact derivative of the reprojection error functional. This allows its rigorous minimization via gradient descent surface evolution. The main difficulty has been to correctly take into account the visibility changes that occur when the surface moves. A geometric and analytical study of these changes is presented and used for the computation of derivative. Our analysis shows the strong influence that the movement of the contour generators has on the reprojection error. As a consequence, during the proper minimization of the reprojection error, the contour generators of the surface are automatically moved to their correct location in the images. Therefore, current methods adding additional silhouettes or apparent contour constraints to ensure this alignment can now be understood and justified by a single criterion: the reprojection error.
GargalloPradosSturm-iccv2007.pdf (470.25 Ko) Télécharger le fichier
Format : Figure, Image
inria-00266287 , version 1 (21-03-2008)
Pau Gargallo, Emmanuel Prados, Peter Sturm. Minimizing the Reprojection Error in Surface Reconstruction from Images. ICCV 2007 - 11th IEEE International Conference on Computer Vision, Oct 2007, Rio de Janeiro, Brazil. pp.1-8, ⟨10.1109/ICCV.2007.4409003⟩. ⟨inria-00266287⟩
271 Consultations
623 Téléchargements
