A gain scheduling strategy for the control and estimation of a remote robot via Internet - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
A gain scheduling strategy for the controller of a remote robot based on Internet and Bluetooth networks is designed and implemented. The Internet communication is based on the Master-Slave structure, UDP protocol. The Slave comprises a PC and a mobile robot, interconnected through the protocol Bluetooth. The Master is a second PC which realizes the remote control, the design of which is based on a remote observer achieving a state prediction of the robot (Slave), despite the variable communication delays, sampling and packets losses. The detected variable time delays serve as the switching signals. The gain scheduling state feedback controller is based on Lyapunov-Krasovskii functional and the approach of LMI, which guarantee the uniform stabilization performance.
CCC2008-file2502.pdf (219.82 Ko) Télécharger le fichier
inria-00266451 , version 1 (22-03-2008)
Wenjuan Jiang, Alexandre Kruszewski, Jean-Pierre Richard, Armand Toguyeni. A gain scheduling strategy for the control and estimation of a remote robot via Internet. CCC'08 - 27th Chinese Control Conference, Jul 2008, Kunming, Yunnan, China. ⟨10.1109/CHICC.2008.4605866⟩. ⟨inria-00266451⟩
343 Consultations
171 Téléchargements
