s'authentifier
version française rss feed
inria-00266552, version 3
Analysis of an M/G/1 queue with repeated inhomogeneous vacations -- Application to IEEE 802.16e power saving
Sara Alouf (Auteur à contacter de préférence) 1, Eitan Altman () 1, Amar Prakash Azad () 1
N° RR-6488 (2008)
Résumé : This report presents a method for analyzing a queueing model with repeated inhomogeneous vacations. At the end of a vacation, the server goes on another vacation, possibly with a different probability distribution, if during the previous vacation there have been no arrivals. In order to get an insight on the influence of parameters on the performance, we choose to study a simple M/G/1 queue (Poisson arrivals and general independent service times) which has the advantage of being tractable analytically. The theoretical model is applied to the problem of power saving for mobile devices in which the sleep durations of a device correspond to the vacations of the server. Various system performance metrics such as the frame response time and the economy of energy are derived. A constrained optimization problem is formulated to maximize the economy of energy achieved in power save mode, with constraints as QoS conditions to be met. An illustration of the proposed methods is shown with a WiMAX system scenario to obtain design parameters for better performance. Our analysis allows us not only to optimize the system parameters for given traffic intensity but also to propose parameters that provide the best performance under worst case conditions.
  • Domaine : Informatique/Réseaux et télécommunications
  • Mots-clés : M/G/1 queue with repeated inhomogeneous vacations – power save mode – system response time – constrained optimization – numerical analysis
  • Référence interne : RR-6488
  • Versions disponibles :  v1 (24-03-2008) v2 (01-04-2008) v3 (02-04-2008)
  • inria-00266552, version 3
  • oai:hal.inria.fr:inria-00266552
  • Contributeur :
  • Soumis le : Mercredi 2 Avril 2008, 16:34:33
  • Dernière modification le : Mercredi 2 Avril 2008, 17:03:08
tous les articles de la base du CCSd...
