Using switching detection and variational equations for the shooting method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optimal Control Applications and Methods Année : 2007
We study in this paper the resolution by single shooting of an optimal control problem with a bang-bang control involving a large number of commutations. We focus on the handling of these commutations regarding the precise computation of the shooting function and its Jacobian. We first observe the impact of a switching detection algorithm on the shooting method results. Then, we study the computation of the Jacobian of the shooting function, by comparing classical finite differences to a formulation using the variational equations. We consider as an application a low thrust orbital transfer with payload maximization. This kind of problem presents a discontinuous optimal control, and involves up to 1800 commutations for the lowest thrust. Copyright c 2000 John Wiley & Sons, Ltd.
Martinon-Gergaud-OCAM2006-preprint.pdf (2.83 Mo) Télécharger le fichier
inria-00271155 , version 1 (08-04-2008)
  • HAL Id : inria-00271155 , version 1
Pierre Martinon, Joseph Gergaud. Using switching detection and variational equations for the shooting method. Optimal Control Applications and Methods, 2007, 28 (2), pp.95-116. ⟨inria-00271155⟩
396 Consultations
332 Téléchargements
