Optimizing the Error Recovery Capabilities of LDPC-Staircase Codes Featuring a Gaussian Elimination Decoding Scheme: Preliminary Results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
The erasure recovery capabilities of LDPC-Triangle and LDPC-Staircase codes can be greatly improved by means of a Gaussian elimination decoding scheme . Thanks to this decoding, the LDPC-Triangle codes are now very close to an ideal code. The LDPC-Staircase codes are also improved but they are not as close to an ideal code as the LDPC-Triangle codes are. Furthermore, for some code rates, the performances of the LDPC-Staircase codes diverge from their asymptotic behavior. This document studies the influence of the N1 parameter of the LDPC-Staircase codes, i.e., the target number of '1s' per column, which in turn controls the left degree of source symbols, on the erasure recovery capabilities of the codes when a Gaussian elimination decoding scheme is used.
ldpc_gauss_and_left_degree.pdf (60.81 Ko) Télécharger le fichier
inria-00271430 , version 1 (09-04-2008)
  • HAL Id : inria-00271430 , version 1
Mathieu Cunche, Vincent Roca. Optimizing the Error Recovery Capabilities of LDPC-Staircase Codes Featuring a Gaussian Elimination Decoding Scheme: Preliminary Results. 2008. ⟨inria-00271430⟩
99 Consultations
141 Téléchargements
