Power Series Composition and Change of Basis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Alin Bostan
  • Fonction : Auteur
  • PersonId : 831654
Bruno Salvy
Éric Schost
  • Fonction : Auteur
  • PersonId : 839026
Efficient algorithms are known for many operations on truncated power series (multiplication, powering, exponential, ...). Composition is a more complex task. We isolate a large class of power series for which composition can be performed efficiently. We deduce fast algorithms for converting polynomials between various bases, including Euler, Bernoulli, Fibonacci, and the orthogonal Laguerre, Hermite, Jacobi, Krawtchouk, Meixner and Meixner-Pollaczek.
Sa01-bostan.pdf (223.71 Ko) Télécharger le fichier
inria-00273385 , version 1 (15-04-2008)
  • HAL Id : inria-00273385 , version 1
  • ARXIV : 0804.2337
Alin Bostan, Bruno Salvy, Éric Schost. Power Series Composition and Change of Basis. ISSAC'08 : International Symposium on Symbolic and Algebraic Computation, Jul 2008, Hagenberg, Austria. ⟨inria-00273385⟩
91 Consultations
270 Téléchargements
