Conformance Testing based on UML State Machines: Automated Test Case Generation, Execution and Evaluation
We describe a comprehensive approach for conformance testing of reactive systems. Based on a formal specification, namely UML state machines, we automatically generate test cases and use them to test the input-output conformance of a system under test. The test cases include not only the stimuli to trigger the system under test, they also include the test oracles to automatically evaluate the test execution. In contrast to Harel Statecharts, state machines behave asynchronously, which makes automatic test case generation a particular challenge. As a prerequisite we have completely formalized a substantial subset of UML state machines that includes complex structured data. The TEAGER tool suite implements our test approach and proves its applicability.
Génie logiciel [cs.SE]
