s'authentifier
version française rss feed
inria-00275382, version 1
From formal proofs to mathematical proofs: a safe, incremental way for building in first-order decision procedures
Frédéric Blanqui () 12, Jean-Pierre Jouannaud () a34, Pierre-Yves Strub () a34
5th IFIP International Conference on Theoretical Computer Science - TCS 2008 273 (2008)
Résumé : We investigate here a new version of the Calculus of Inductive Constructions (CIC) on which the proof assistant Coq is based: the Calculus of Congruent Inductive Constructions, which truly extends CIC by building in arbitrary first-order decision procedures: deduction is still in charge of the CIC kernel, while computation is outsourced to dedicated first-order decision procedures that can be taken from the shelves provided they deliver a proof certificate. The soundness of the whole system becomes an incremental property following from the soundness of the certificate checkers and that of the kernel. A detailed example shows that the resulting style of proofs becomes closer to that of the working mathematician.
  • Domaine : Informatique/Logique en informatique
  • Mots-clés : proof assistants – proof – lambda-calculus – calculus of constructions – certification – decision procedures – first-order theory – type theory
  • inria-00275382, version 1
  • oai:hal.inria.fr:inria-00275382
  • Contributeur :
  • Soumis le : Mercredi 23 Avril 2008, 15:41:08
  • Dernière modification le : Lundi 6 Juin 2011, 14:34:16
tous les articles de la base du CCSd...
