Locally Uniform Anisotropic Meshing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
Camille Wormser
  • Fonction : Auteur
  • PersonId : 843113
Mariette Yvinec
Anisotropic meshes are triangulations of a given domain in the plane or in higher dimensions, with elements elongated along prescribed directions. Anisotropic triangulations have been shown to be particularly well suited for interpolation of functions or numerical modeling. We propose a new approach to anisotropic mesh generation, relying on the notion of locally uniform an\-i\-so\-trop\-ic mesh. A locally uniform anisotropic mesh is a mesh such that the star around each vertex $v$ coincides with the star that $v$ would have if the metric on the domain was uniform and equal to the metric at $v$. This definition allows to define a simple refinement algorithm which relies on elementary predicates, and provides, after completion, an anisotropic mesh in dimensions 2 and 3.
aniso-hal.pdf (285.27 Ko) Télécharger le fichier
inria-00275430 , version 1 (23-04-2008)
  • HAL Id : inria-00275430 , version 1
Jean-Daniel Boissonnat, Camille Wormser, Mariette Yvinec. Locally Uniform Anisotropic Meshing. 24th Annual Symposium on Computational Geometry, SoCG'08, ACM, Jun 2008, Maryland, United States. ⟨inria-00275430⟩
251 Consultations
228 Téléchargements
