Fast state estimation in linear time-invariant systems: an algebraic approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this note, an algebraic approach for state estimation of linear time invariant systems is developed. This approach is based on the following mathematical tools: Laplace transform, Leibniz formula and operational calculus. A generalized expression of the state variables in function of the integrals of the output and the input is obtained. The example of a DC motor system and simulation results are given to illustrate the performance of the proposed approach.
Automatique
LTIMed.pdf (712.29 Ko) Télécharger le fichier
inria-00276607 , version 1 (30-04-2008)
  • HAL Id : inria-00276607 , version 1
Yang Tian, Thierry Floquet, Wilfrid Perruquetti. Fast state estimation in linear time-invariant systems: an algebraic approach. Med 08, Jun 2008, Ajaccio, France. ⟨inria-00276607⟩
355 Consultations
132 Téléchargements
