A Tight Bound for the Delaunay Triangulation of Points on a Polyhedron - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Nina Amenta
  • Fonction : Auteur
  • PersonId : 835271
Olivier Devillers
We show that the Delaunay triangulation of a set of n points distributed nearly uniformly on a p-dimensional polyhedron (not necessarily convex) in d-dimensional Euclidean space is O(n^((d-k+1)/p)), where k = ceil(d+1)/(p+1)$. This bound is tight, and improves on the prior upper bound for most values of p.
RR-6522.pdf (316.92 Ko) Télécharger le fichier
inria-00277899 , version 1 (07-05-2008)
inria-00277899 , version 2 (13-05-2008)
  • HAL Id : inria-00277899 , version 2
Nina Amenta, Dominique Attali, Olivier Devillers. A Tight Bound for the Delaunay Triangulation of Points on a Polyhedron. [Research Report] RR-6522, -; INRIA. 2008. ⟨inria-00277899v2⟩
254 Consultations
241 Téléchargements
