On Correlated Availability in Internet-Distributed Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2008
As computer networks rapid ly increase in size and speed, Internet-distributed systems such as P2P, volun- teer computing, and Grid systems are increasingly com- mon. A precise and accurate characterization of Inter- net resources is important for the design and evalua- tion of such Internet-distributed systems, yet our pic- ture of the Internet landscape is not perfectly clear. To improve this picture, we measure and characterize the time dynamics of availability in a large-scale Internet- distributed system with over 110,000 hosts. Our char- acterization focuses on identifying patterns of corre- lated availability. We determine scalable and accurate clustering techniques and distance metrics for auto- matical ly detecting significant availability patterns. By means of clustering, we identify groups of resources with correlated availability that exhibit similar time ef- fects. Then we show how these correlated clusters of resources can be used to improve resource management for paral lel applications in the context of volunteer com- puting.
RR-6539.pdf (864.67 Ko) Télécharger le fichier
inria-00279991 , version 1 (16-05-2008)
inria-00279991 , version 2 (21-05-2008)
  • HAL Id : inria-00279991 , version 2
Derrick Kondo, Artur Andrzejak, David P. Anderson. On Correlated Availability in Internet-Distributed Systems. [Technical Report] RR-6539, INRIA. 2008. ⟨inria-00279991v2⟩
236 Consultations
231 Téléchargements
