NORINE: a database of nonribosomal peptides. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nucleic Acids Research Année : 2008
Norine is the first database entirely dedicated to nonribosomal peptides (NRPs). In bacteria and fungi, in addition to the traditional ribosomal proteic biosynthesis, an alternative ribosome-independent pathway called NRP synthesis allows peptide production. It is performed by huge protein complexes called nonribosomal peptide synthetases (NRPSs). The molecules synthesized by NRPS contain a high proportion of nonproteogenic amino acids. The primary structure of these peptides is not always linear but often more complex and may contain cycles and branchings. In recent years, NRPs attracted a lot of attention because of their biological activities and pharmacological properties (antibiotic, immunosuppressor, antitumor, etc.). However, few computational resources and tools dedicated to those peptides have been available so far. Norine is focused on NRPs and contains more than 700 entries. The database is freely accessible at http://bioinfo.lifl.fr/norine/. It provides a complete computational tool for systematic study of NRPs in numerous species, and as such, should permit to obtain a better knowledge of these metabolic products and underlying biological mechanisms, and ultimately to contribute to the redesigning of natural products in order to obtain new bioactive compounds for drug discovery.
NAR08.pdf (1.15 Mo) Télécharger le fichier
inria-00281012 , version 1 (16-05-2013)
Ségolène Caboche, Maude Pupin, Valérie Leclère, Arnaud Fontaine, Philippe Jacques, et al.. NORINE: a database of nonribosomal peptides.. Nucleic Acids Research, 2008, Database issue, 36 (Database issue), pp.D326-31. ⟨10.1093/nar/gkm792⟩. ⟨inria-00281012⟩
332 Consultations
190 Téléchargements
