Chronicles for On-line Diagnosis of Distributed Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
The formalism of chronicles has been proposed a few years ago to monitor and diagnose dynamic physical systems and has been successfully used for real-time appli- cations. A chronicle, expressed by a set of time-constrained events, describes the situations to monitor. Even if efficient algorithms exist to analyze a flow of observed events and to rec- ognize on-the-fly the matching chronicles, it is now well-known that distributed approaches are better suited to monitor actual systems. In this report, we adapt the chronicle-based approach to a distributed context. We propose a decentralized architecture and the cor- responding software, implemented under the name of CarDeCRS (Chronicles Applied to error Recognition in Distributed Environments, through CRS), which in charge of synchro- nizing the local diagnoses, computed by chronicle-based local diagnosers, and merging them into a global diagnosis. This work is motivated by an application that aims at monitoring the behaviour of software components within the WS-Diamond European project. In this context, a request is sent to a web service which collaborates with other services to provide the adequate reply. Faults may propagate from one service to another and diagnosing them is a crucial issue, in order to react properly. We use a simplified example of a e-foodshop web service to illustrate our proposal.
PI-1890.pdf (450.94 Ko) Télécharger le fichier
inria-00282294 , version 1 (27-05-2008)
  • HAL Id : inria-00282294 , version 1
Xavier Le Guillou, Marie-Odile Cordier, Sophie Robin, Laurence Rozé. Chronicles for On-line Diagnosis of Distributed Systems. [Research Report] PI 1890, 2008, pp.49. ⟨inria-00282294⟩
194 Consultations
158 Téléchargements
