UML/MARTE CCSL, Signal and Petri nets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
UML goal of being a general-purpose modeling language discards the possibility to adopt too precise and strict a semantics. Users are to refine or define the semantics in their domain specific profiles. In the UML Profile for Modeling and Analysis of Real-Time and Embedded systems, we have defined a broadly expressive Time Model to provide a generic timed interpretation for UML models. Our clock constraint specification language supports the specification of systems with multiple clock domains. Starting with a priori independent clocks, we progressively compose them to get a family of possible executions. Our language supports both synchronous and asynchronous compositions, just like the synchronous language Signal, but also allows explicit non determinism. In this paper, we give a formal semantics to a core subset of MARTE clock constraint languages and we give an equivalent interpretation of this kernel in two other very different formal languages, Signal and Time Petri Nets.
RR-6545.pdf (755.72 Ko) Télécharger le fichier
inria-00283077 , version 1 (29-05-2008)
inria-00283077 , version 2 (02-06-2008)
inria-00283077 , version 3 (10-06-2008)
inria-00283077 , version 4 (12-06-2008)
  • HAL Id : inria-00283077 , version 4
Frédéric Mallet, Charles André. UML/MARTE CCSL, Signal and Petri nets. [Research Report] RR-6545, INRIA. 2008. ⟨inria-00283077v4⟩
338 Consultations
223 Téléchargements
