Slope heuristics for variable selection and clustering via Gaussian mixtures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Cathy Maugis
Bertrand Michel
Specific Gaussian mixtures are considered to solve simultaneously variable selection and clustering problems. A penalized likelihood criterion is proposed in Maugis and Michel (2008) to choose the number of mixture components and the relevant variable subset. This criterion is depending on unknown constants to be approximated in practical situations. A "slope heuristics" method is proposed and experimented to deal with this practical problem in this context. Numerical experiments on simulated datasets, a curve clustering example and a genomics application highlight the interest of the proposed heuristics.
RR-6550.pdf (645.7 Ko) Télécharger le fichier
inria-00284620 , version 1 (03-06-2008)
inria-00284620 , version 2 (04-06-2008)
  • HAL Id : inria-00284620 , version 2
Cathy Maugis, Bertrand Michel. Slope heuristics for variable selection and clustering via Gaussian mixtures. [Research Report] RR-6550, INRIA. 2008. ⟨inria-00284620v2⟩
194 Consultations
370 Téléchargements
