s'authentifier
version française rss feed
inria-00287845, version 1
Lower bounds for evolution strategies using VC-dimension
Olivier Teytaud () 12, Hervé Fournier 3
Parallel Problem Solving from Nature (2008) 10 pages
Résumé : We derive lower bounds for comparison-based or selection-based algorithms, improving existing results in the continuous setting, and extending them to non-trivial results in the discrete case. We introduce for that the use of the VC-dimension of the level sets of the fitness functions; results are then obtained through the use of Sauer's lemma. In the special case of optmization of the sphere function, improved lower bounds are obtained by bounding the possible number of sign conditions realized by some systems of equations. The results include several applications to the parametrization of sequential or parallel algorithms of type $\mul$-ES.
  • Domaine : Mathématiques/Optimisation et contrôle
  • Mots-clés : VC-dimension – Convergence rate – Evolution Strategies
  • inria-00287845, version 1
  • oai:hal.inria.fr:inria-00287845
  • Contributeur :
  • Soumis le : Vendredi 13 Juin 2008, 10:09:57
  • Dernière modification le : Jeudi 14 Août 2008, 11:49:31
tous les articles de la base du CCSd...
