s'authentifier
version française rss feed
inria-00289361, version 1
Vers des supports d'exécution capables d'exploiter les machines multicœurs hétérogènes
Cédric Augonnet () 12
(2008)
Résumé : Approaching the theoretical performance of heterogeneous multicore architectures, equipped with specialized accelerators, is a challenging issue. Unlike regular CPUs that can transparently access the whole global memory address range, accelerators usually embed local memory on which they perform all their computations using a specific instruction set. While many research efforts have been devoted to offloading parts of a program over such coprocessors, the real challenge is to find a programming model providing a unified view of all available computing units. In this document, we present an original runtime system providing a high-level, unified execution model allowing seamless execution of tasks over the underlying heterogeneous hardware. The runtime is based on a hierarchical memory management facility and on a codelet scheduler. We demonstrate the efficiency of our solution with a LU decomposition for both homogeneous (3.8 speedup on 4 cores) and heterogeneous machines (95% efficiency). We also show that a "granularity aware" scheduling can improve execution time by 35%.
  • 1 :  RUNTIME (INRIA Bordeaux - Sud-Ouest)
  • INRIA – CNRS : UMR5800 – Université Sciences et Technologies - Bordeaux I – École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB)
  • 2 :  Laboratoire Bordelais de Recherche en Informatique (LaBRI)
  • CNRS : UMR5800 – Université Sciences et Technologies - Bordeaux I – École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB) – Université Victor Segalen - Bordeaux II
  • Domaine : Informatique/Système d'exploitation
    Informatique/Calcul parallèle, distribué et partagé
  • inria-00289361, version 1
  • oai:hal.inria.fr:inria-00289361
  • Contributeur :
  • Soumis le : Vendredi 20 Juin 2008, 13:54:18
  • Dernière modification le : Vendredi 6 Février 2009, 14:11:07
tous les articles de la base du CCSd...
