On the Impact of the Mobility on Convergence Speed of Population Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Population protocols provide theoretical foundations for mobile tiny device networks in which global behavior emerges from a set of simple interactions between anonymous agents. The works in this area mostly focus on studying the computational power of the model. Results hold as long as a fair scheduler, ensuring that all reachable system states are endlessly reached, governs the interactions between nodes. This assumption is crucial to ensure that the protocols eventually converge. This paper studies for the first time the impact of the agents? mobility model on the convergence speed of population protocols. We perform our study by considering several mobility models traditionally used in the ad-hoc network community. We propose an augmented population protocol model where each edge of the interaction graph is weighted, representing the probability of two agents to interact. This models the behaviour of the scheduler with respect to various mobility models. We empirically show that mobility models do have a significant impact on the convergence speed of the protocols. In fact, we observe that the uniform distribution always provides the best convergence time. Such a model is representative of the well-known random-way point model used to evaluate most of mobile ad-hoc network protocols. We then formally prove that a uniform distribution of weights provides the lowest bound of average convergence speed for any population protocol.
RR-6580.pdf (456.79 Ko) Télécharger le fichier
inria-00296584 , version 1 (12-07-2008)
inria-00296584 , version 2 (27-11-2008)
  • HAL Id : inria-00296584 , version 2
Yann Busnel, Marin Bertier, Anne-Marie Kermarrec. On the Impact of the Mobility on Convergence Speed of Population Protocols. [Research Report] RR-6580, INRIA. 2008, pp.30. ⟨inria-00296584v2⟩
445 Consultations
142 Téléchargements
