An error analysis in the algebraic estimation of a noisy sinusoidal signal
The classic example of a noisy sinusoidal signal permits for the first time to derive an error analysis for a new algebraic and non-asymptotic estimation technique. This approach yields a selection of suitable parameters in the estimation procedure, in order to minimize the noise corruption.
Analyse numérique [math.NA]
