inria-00300770, version 1
Fluid-Structure Interaction and multi-body contact. Application to the aortic valves
Matteo Astorino
a, 1Jean-Frédéric Gerbeau
a, 1Olivier Pantz
b, 2Karim-Frédéric Traore
a, 1
N° RR-6583 (2008)
Résumé : We present a partitioned procedure for fluid-structure interaction problems in which contacts among different deformable bodies can occur. A typical situation is the movement of a thin valve (e.g. the aortic valve) immersed in an incompressible viscous fluid (e.g. the blood). In the proposed strategy the fluid and structure solvers are considered as independent ``black-boxes'' that exchange forces and displacements; the structure solvers are moreover not supposed to manage contact by themselves. The hypothesis of non-penetration among solid objects defines a non-convex optimization problem. To solve the latter, we use an internal approximation algorithm that is able to directly handle the cases of thin structures and self-contacts. A numerical simulation on an idealized aortic valve is finally realized with the aim of illustrating the proposed scheme.
- a – INRIA
- b – Ecole Polytechnique
- 1 : REO (INRIA Rocquencourt)
- INRIA – Laboratoire Jacques-Louis Lions
- 2 : Centre de Mathématiques Appliquées (CMAP)
- CNRS : UMR7641 – Université de Versailles Saint-Quentin-en-Yvelines – Polytechnique - X
- Domaine : Mathématiques/Analyse numérique
- Mots-clés : fluid-structure interaction – contact – cardiac valves
- Référence interne : RR-6583
- inria-00300770, version 1
- http://hal.inria.fr/inria-00300770
- oai:hal.inria.fr:inria-00300770
- Contributeur : Jean-Frédéric Gerbeau
- Soumis le : Samedi 19 Juillet 2008, 21:16:41
- Dernière modification le : Mercredi 23 Juillet 2008, 13:46:32
Documents associés
Exporter
