Analytical Solution for Wave Propagation in Stratified Poroelastic Medium. Part I: the 2D Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We are interested in the modeling of wave propagation in poroelastic media. We consider the biphasic Biot's model in an infinite bilayered medium, with a plane interface. We adopt the Cagniard-De Hoop's technique. This report is devoted to the calculation of analytical solutions in two dimensions. The solutions we present here have been used to validate numerical codes.
RR-6591.pdf (372.86 Ko) Télécharger le fichier
inria-00305395 , version 1 (24-07-2008)
  • HAL Id : inria-00305395 , version 1
  • ARXIV : 0807.3864
Julien Diaz, Abdelaâziz Ezziani. Analytical Solution for Wave Propagation in Stratified Poroelastic Medium. Part I: the 2D Case. [Research Report] RR-6591, INRIA. 2008, pp.27. ⟨inria-00305395⟩
227 Consultations
297 Téléchargements
