Analytical Solution for Wave Propagation in Stratified Poroelastic Medium. Part II: the 3D Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We are interested in the modeling of wave propagation in poroelastic media. We consider the biphasic Biot's model in an infinite bilayered medium with a plane interface. We adopt the Cagniard-De Hoop's technique. This report is devoted to the calculation of analytical solution in three dimension.
RR-6596.pdf (404.38 Ko) Télécharger le fichier
inria-00305891 , version 1 (25-07-2008)
  • HAL Id : inria-00305891 , version 1
  • ARXIV : 0807.4067
Julien Diaz, Abdelaâziz Ezziani. Analytical Solution for Wave Propagation in Stratified Poroelastic Medium. Part II: the 3D Case. [Research Report] RR-6596, INRIA. 2008, pp.40. ⟨inria-00305891⟩
168 Consultations
121 Téléchargements
