Trains of keypoints for 3d object recognition
This paper presents a 3D object recognition method that exploits the spatio-temporal coherence of image sequences to capture the object most relevant features. We start from an image sequence that describes the object's visual appearance from different view points. We extract local features (SIFT) and track them over the sequence. The tracked interest points form trains of features that are used to build a vocabulary for the object. Training images are represented with respect to that vocabulary and an SVM classier is trained to recognize the object. We present very promising results on a dataset of 11 objects. Tests are performed under varying illumination, scale, and scene clutter.
icpr06.pdf (240.22 Ko)
Télécharger le fichier
Format : Figure, Image
