A contrast equalization procedure for change detection algorithms: applications to remotely sensed images of urban areas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Alexandre Fournier
  • Fonction : Auteur
  • PersonId : 848149
Pierre Weiss
Gilles Aubert
  • Fonction : Auteur
  • PersonId : 841269
We propose an algorithm that equalizes the contrast of grayscale image pairs to simplify the task of change detection. To ensure robustness of the detection under different illumination conditions, some authors recently proposed algorithms that compare the level lines of the images. We show - using ideas from the “shape from shading” community - that under directed light, a necessary condition for the level lines to be illumination invariant is that the underlying surfaces be developable. The surfaces of cities can be modeled as piecewise smooth developable surfaces, and it is therefore sensible to make use of the level lines for change detection. Our algorithm is robust and efficient both on synthetic OpenGL scenes and natural Quickbird images.
icpr2008.pdf (1.58 Mo) Télécharger le fichier
inria-00307727 , version 1 (29-07-2008)
  • HAL Id : inria-00307727 , version 1
Alexandre Fournier, Pierre Weiss, Laure Blanc-Féraud, Gilles Aubert. A contrast equalization procedure for change detection algorithms: applications to remotely sensed images of urban areas. International Conference on Pattern Recognition, International Association of Pattern Recognition, Dec 2008, Tampa, United States. pp.1-4. ⟨inria-00307727⟩
127 Consultations
143 Téléchargements
