Minimizing the Multi-view Stereo Reprojection Error for Triangular Surface Meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This article proposes a variational multi-view stereo vision method based on meshes for recovering 3D scenes (shape and radiance) from images. Our method is based on generative models and minimizes the reprojection error (difference between the observed images and the images synthesized from the reconstruction). Our contributions are twofold. 1) For the first time, we rigorously compute the gradient of the reprojection error for non smooth surfaces defined by discrete triangular meshes. The gradient correctly takes into account the visibility changes that occur when a surface moves; this forces the contours generated by the reconstructed surface to perfectly match with the apparent contours in the input images. 2) We propose an original modification of the Lambertian model to take into account deviations from the constant brightness assumption without explicitly modelling the reflectance properties of the scene or other photometric phenomena involved by the camera model. Our method is thus able to recover the shape and the diffuse radiance of non Lambertian scenes.
delaunoy-prados-etal-BMVC08.pdf (518.32 Ko) Télécharger le fichier
Format : Figure, Image
inria-00308944 , version 1 (04-08-2008)
Amael Delaunoy, Emmanuel Prados, Pau Gargallo I Piracés, Jean-Philippe Pons, Peter Sturm. Minimizing the Multi-view Stereo Reprojection Error for Triangular Surface Meshes. BMVC 2008 - British Machine Vision Conference, Sep 2008, Leeds, United Kingdom. pp.1-10, ⟨10.5244/C.22.58⟩. ⟨inria-00308944⟩
1069 Consultations
1085 Téléchargements
