inria-00311115, version 1
A Model Driven Design Framework for High Performance Embedded Systems
Abdoulaye Gamatié
1, 2Sébastien Le Beux
1, 2Éric Piel
a, 1Anne Etien
1, 2Rabie Ben Atitallah
1, 2Philippe Marquet
1, 2Jean-Luc Dekeyser
1, 2
N° RR-6614 (2008)
Résumé : Modern embedded systems integrate more and more complex functionalities. At the same time, the semiconductor technology advances enable to increase the amount of hardware resources on a chip for the execution. High performance embedded systems specifically deal with the optimized usage of such hardware resources to efficiently execute their functionalities. The design of high performance embedded systems mainly relies on the following challenging issues: first, how to deal with the parallelism in order to increase the performances; second, how to abstract their implementation details in order to manage their complexity; third, how to refine these abstract representations in order to produce efficient implementations. This paper presents the Gaspard design framework for high performance embedded systems as a solution to the above issues. Gaspard uses the repetitive Model of Computation (MoC), which offers a powerful expression of the parallelism available in both system functionality and architecture. Embedded systems are designed at a high abstraction level with the MARTE (Modeling and Analysis of Real-time and Embedded systems) standard profile, in which our repetitive MoC is described by the so-called Repetitive Structure Modeling (RSM) package. Based on the Model-Driven Engineering (MDE) paradigm, MARTE models are refined towards lower abstraction levels, which make possible the design space exploration. By combining all these capabilities, Gaspard allows the designers to automatically generate code for formal verification, simulation and hardware synthesis from high level specifications of high performance embedded systems. Its effectiveness is demonstrated with the design of an embedded system for a multimedia application.
- a – Technical University of Delft, The Netherlands.
- 1 : DART (INRIA Lille - Nord Europe)
- INRIA – CNRS : UMR8022 – Université Lille 1 - Sciences et Technologies
- 2 : Laboratoire d'Informatique Fondamentale de Lille (LIFL)
- CNRS : UMR8022 – INRIA – IRCICA – Université Lille 1 - Sciences et Technologies
- Domaine : Informatique/Génie logiciel
Informatique/Calcul parallèle, distribué et partagé
Informatique/Modélisation et simulation
Informatique/Systèmes embarqués - Référence interne : RR-6614
- inria-00311115, version 1
- http://hal.inria.fr/inria-00311115
- oai:hal.inria.fr:inria-00311115
- Contributeur : Abdoulaye Gamatié
- Soumis le : Mardi 12 Août 2008, 19:00:25
- Dernière modification le : Mercredi 13 Août 2008, 10:46:06
Documents associés
Exporter
