A branch-and-cut algorithm for a resource-constrained scheduling problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue RAIRO - Operations Research Année : 2007
This paper is devoted to the exact resolution of a strongly NP-hard resource-constrained scheduling problem, the Process Move Programming problem, which arises in relation to the operability of certain high-availability real-time distributed systems. Based on the study of the polytope defined as the convex hull of the incidence vectors of the admissible process move programs, we present a branch-and-cut algorithm along with extensive computational results demonstrating its practical relevance, in terms of both exact and approximate resolution when the instance size increases.
RAIRO.pdf (168.46 Ko) Télécharger le fichier
inria-00311533 , version 1 (18-08-2008)
Renaud Sirdey, Hervé Kerivin. A branch-and-cut algorithm for a resource-constrained scheduling problem. RAIRO - Operations Research, 2007, 41 (3), pp.235-251. ⟨10.1051/ro:2007021⟩. ⟨inria-00311533⟩
122 Consultations
157 Téléchargements
