LRing: A Layered Ring Topology for Reliable Streaming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
To efficiently and stably deliver streaming media, researchers have developed technical solutions that are either based on a tree model or based on a mesh model. The disadvantage of tree-based model is limited stability and high cost, while the disadvantage of mesh-based model is low efficiency on streaming rate when nodes churn. In this paper, we propose LRing – A Layered Ring Topology for reliable streaming system, which well balance the maximum streaming rate and reliable streaming data in the system as well as achieve high utilization of node's cache. The simulation experiment demonstrates the effectiveness of LRing.
LRing_en_for_AdhocAmC_2008_xkrevised.pdf (96.87 Ko) Télécharger le fichier
inria-00312743 , version 1 (26-08-2008)
  • HAL Id : inria-00312743 , version 1
Wen Jigang, Li Renfa, Xie Kun, Li Rui. LRing: A Layered Ring Topology for Reliable Streaming. 1st International Workshop on Ad-hoc Ambient Computing, David Coudert, Sep 2008, Sophia Antipolis, France. ⟨inria-00312743⟩
Collections
ADHOCAMC08
72 Consultations
100 Téléchargements
