Numerical differentiation with annihilators in noisy environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Algorithms Année : 2009
Numerical differentiation in noisy environment is revised through an algebraic approach. For each given order, an explicit formula yielding a pointwise derivative estimation is derived, using elementary differential algebraic operations. These expressions are composed of iterated integrals of the noisy observation signal. We show in particular that the introduction of delayed estimates affords significant improvement. An implementation in terms of a classical finite impulse response (FIR) digital filter is given. Several simulation results are presented.
Num_differentiation.pdf (355.55 Ko) Télécharger le fichier
inria-00319240 , version 1 (07-09-2008)
Mamadou Mboup, Cédric Join, Michel Fliess. Numerical differentiation with annihilators in noisy environment. Numerical Algorithms, 2009, 50 (4), pp.439-467. ⟨10.1007/s11075-008-9236-1⟩. ⟨inria-00319240⟩
3294 Consultations
2222 Téléchargements
