Computing the uncertainty of the 8 point algorithm for fundamental matrix estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Fundamental matrix estimation is difficult since it is often based on correspondences that are spoilt by noise and outliers. Outliers must be thrown out via robust statistics, and noise gives uncertainty. In this article we provide a closed-form formula for the uncertainty of the so-called 8 point algorithm, which is a basic tool for fundamental matrix estimation via robust methods. As an application, we modify a well established robust algorithm accordingly, leading to a new criterion to recover point correspondences under epipolar constraint, balanced by the uncertainty of the estimation.
article.pdf (645.17 Ko) Télécharger le fichier
inria-00319704 , version 1 (20-09-2010)
  • HAL Id : inria-00319704 , version 1
Frédéric Sur, Nicolas Noury, Marie-Odile Berger. Computing the uncertainty of the 8 point algorithm for fundamental matrix estimation. 19th British Machine Vision Conference - BMVC 2008, British Machine Vision Association, Sep 2008, Leeds, United Kingdom. pp.10. ⟨inria-00319704⟩
412 Consultations
289 Téléchargements
