Geometrical Conditions for Output Depending Observability Normal Form - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We give geometrical conditions, which guarantee the existence of a diffeomorphism in order to transform a nonlinear system without inputs into a canonical normal form depending on its output. Moreover we extend our results to a class of systems with inputs. We end this paper by some examples and its simulations to highlight the proposed algorithm.
Automatique
CDC.pdf (122.32 Ko) Télécharger le fichier
inria-00319964 , version 1 (09-09-2008)
Gang Zheng, Driss Boutat, Jean-Pierre Null Barbot. Geometrical Conditions for Output Depending Observability Normal Form. CDC 2008 - 47th IEEE Conference on Decision and Control, Dec 2008, Cancun, Mexico. pp.5075-5079, ⟨10.1109/CDC.2008.4739505⟩. ⟨inria-00319964⟩
657 Consultations
172 Téléchargements
