inria-00320645, version 1
Using linear programming duality for solving finite horizon Dec-POMDPs
Raghav Aras
1Alain Dutech
1François Charpillet
1
N° RR-6641 (2008)
Résumé : This paper studies the problem of finding an optimal finite horizon joint policy for a decentralized partially observable Markov decision process (Dec-POMDP). We present a new algorithm for finding an optimal joint policy. The algorithm is based on the fact that the necessary condition for a joint policy to be optimal is that it be locally optimal (that is, a Nash equilibrium). Through the application of linear programming duality, the necessary condition can be transformed to a nonlinear program which can then further be transformed to a 0-1 mixed integer linear program (MILP) whose optimal solution is an optimal joint policy (in the sequence form). The proposed algorithm thus consists of solving this 0-1 MILP. Computational experience of the 0-1 MILP on two and three agent DEC-POMDPs gives mixed results. On some problems it is faster than existing algorithms, on others it is slower.
- 1 : MAIA (INRIA Lorraine - LORIA)
- INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
- Domaine : Informatique/Système multi-agents
Informatique/Informatique et théorie des jeux
Informatique/Recherche opérationnelle - Mots-clés : Dec-POMDPs – decentralized problems
- Référence interne : RR-6641
- inria-00320645, version 1
- http://hal.inria.fr/inria-00320645
- oai:hal.inria.fr:inria-00320645
- Contributeur : Raghav Aras
- Soumis le : Mardi 16 Septembre 2008, 14:49:56
- Dernière modification le : Mardi 30 Septembre 2008, 14:02:51
Documents associés
Exporter
