Mobile Databases: a Selection of Open Issues and Research Directions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIGMOD record Année : 2004
Jalel Ben-Othman
Gérôme Canals
  • Fonction : Auteur
  • PersonId : 830484
Stéphane Gançarski
Rachid Guerraoui
  • Fonction : Auteur
  • PersonId : 853670
Pascal Molli
This paper reports on the main results of a specific action on mobile databases conducted by CNRS in France from October 2001 to December 2002. The objective of this action was to review the state of progress in mobile databases and identify major research directions for the French database community. Rather than provide a survey of all important issues in mobile databases, this paper gives an outline of the directions in which the action participants are now engaged, namely: copy synchronization in disconnected computing, mobile transactions, database embedded in ultra-light devices, data confidentiality, P2P dissemination models and middleware adaptability.
P04.pdf (155.34 Ko) Télécharger le fichier
inria-00320861 , version 1 (11-09-2008)
Guy Bernard, Jalel Ben-Othman, Luc Bouganim, Gérôme Canals, Sophie Chabridon, et al.. Mobile Databases: a Selection of Open Issues and Research Directions. SIGMOD record, 2004, Special Issue : Data engineering for life sciences, 33 (2), pp.78-83. ⟨10.1145/1024694.1024708⟩. ⟨inria-00320861⟩
888 Consultations
1189 Téléchargements
