Fast state estimation in linear time-varying systems: an algebraic approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this note, an algebraic approach for state estimation of linear time-varying (LTV) systems is introduced. This approach is based on the following mathematical tools: Laplace transform, Leibniz formula, operational calculus and distribution theory. A generalized expression of the state variables as a function of the integrals of the output and the input is obtained. The example of a DC motor system and some simulation results are given to illustrate the performance of the proposed approach.
Automatique
08_LTV_final.pdf (765.1 Ko) Télécharger le fichier
inria-00320976 , version 1 (11-09-2008)
  • HAL Id : inria-00320976 , version 1
Yang Tian, Thierry Floquet, Wilfrid Perruquetti. Fast state estimation in linear time-varying systems: an algebraic approach. CDC, Dec 2008, Mexique, Mexico. ⟨inria-00320976⟩
209 Consultations
410 Téléchargements
