Gaussian fields for semi-supervised regression and correspondence learning
Gaussian fields (GF) have recently received considerable attention for dimension reduction and semi-supervised classification. In this paper we show how the GF framework can be used for semi-supervised regression on high-dimensional data. We propose an active learning strategy based on entropy minimization and a maximum likelihood model selection method. Furthermore, we show how a recent generalization of the LLE algorithm for correspondence learning can be cast into the GF framework, which obviates the need to choose a representation dimensionality.
Apprentissage [cs.LG]
verbeek05pr_final.pdf (449.78 Ko)
Télécharger le fichier
Format : Figure, Image
